Hello currently I am getting the following error:
Microsoft JScript runtime error: Unable to get value of the property 'valueOf': object is null or undefined
This is happening in the following dynamic javascript function:
isDataKeyEqual: function (dataKey)
///<summary locid="M:J#Infragistics.Web.UI.GridRow.isDataKeyEqual">
///Compares provided data key with the row's data key and returns a
///boolean value indicating whether these are equal.
///</summary>
///<param name="dataKey" type="Array">
///A data key to compare with the row's one.
///</param>
///<returns type="Boolean">
///Boolean value indicating whether the passed in data key is equal to the row's one.
///</returns>
var rowDataKey = this.get_dataKey();
if (rowDataKey && dataKey && rowDataKey.length == dataKey.length)
for (var i = 0; i < dataKey.length; i++)
/* DAY 8/23/11 84816- Row cannot be found on client with compound key that contains Date */
if (rowDataKey[i].valueOf && dataKey[i].valueOf && rowDataKey[i].valueOf() != dataKey[i].valueOf())
return false;
else if ((!rowDataKey[i].valueOf || !dataKey[i].valueOf) && rowDataKey[i] != dataKey[i])
return true;
Here's how I have my grid configured:
<ig:WebDataGrid ID="wdgSPSearch" runat="server" AutoGenerateColumns="False" Width="100%" EnableDataViewState="True" EnableViewState="True"
OnDataBound="wdgSPSearch_DataBound" OnInitializeRow="wdgSPSearch_InitializeRow"
OnItemCommand="wdgSPSearch_ItemCommand">
<Columns>
<ig:TemplateDataField Key="SELECT" Width="40px">
<ItemTemplate>
<input type="checkbox" id="SelectCheckBox" class="ServiceProviderSelection" runat="server"/>
</ItemTemplate>
</ig:TemplateDataField>
<ig:UnboundField Key="SUPERVISOR" Header-Text="Supervisor" Width="100px">
<Header Text="Supervisor" />
</ig:UnboundField>
<ig:UnboundField Key="CRAFT_GROUPS" Header-Text="Craft Group(s)" Width="130px">
<Header Text="Craft Group(s)" />
<ig:BoundDataField DataFieldName="STATUS_NAME" Key="STATUS_NAME" Width="60px">
<Header Text="Status" />
</ig:BoundDataField>
<ig:UnboundField Key="SP_NUM_NAME" Width="200px" HtmlEncode="false">
<Header Text="Service Provider" />
<ig:BoundDataField DataFieldName="AB_NUMBER" Key="AB_NUMBER" Hidden="true">
<Header Text="AB_NUMBER" />
<ig:UnboundField Key="CURRENT_DAY" Width="55px">
<Header TemplateId="currDayDateHeaderTemplate" />
<ig:UnboundField Key="TOMMORROW" Width="55px">
<Header TemplateId="secondDayDateHeaderTemplate" />
<ig:UnboundField Key="TOMMORROW_PLUS_ONE" Width="55px">
<Header TemplateId="thirdDayDateHeaderTemplate" />
<ig:UnboundField Key="TOMMORROW_PLUS_TWO" Width="55px">
<Header TemplateId="fourthDayDateHeaderTemplate" />
<ig:UnboundField Key="TOMMORROW_PLUS_THREE" Width="55px">
<Header TemplateId="fifthDayDateHeaderTemplate" />
<ig:UnboundField Key="TOMMORROW_PLUS_FOUR" Width="55px">
<Header TemplateId="sixthDayDateHeaderTemplate" />
<ig:UnboundField Key="TOMMORROW_PLUS_FIVE" Width="55px">
<Header TemplateId="seventhDayDateHeaderTemplate"></Header>
<ig:UnboundField Key="PERCENT_ALLOCATED" Header-Text="% Allocated" Width="90px">
<Header Text="% Allocated" />
<ig:TemplateDataField Key="ASSIGNMENTS" Width="90px">
<Header Text="Assignments" />
<asp:LinkButton runat="server" ID="lbtnAssignments" CssClass="LoadingItem" CommandName="SELECT_ASSIGNMENTS"
CommandArgument='<%# Eval("AB_NUMBER") %>'>Assignments</asp:LinkButton>
<ig:TemplateDataField Key="SCHEDULE" Width="90px">
<Header Text="Schedule" />
<asp:LinkButton runat="server" ID="lbtnSchedule" CommandName="SELECT_SCHEDULE" CssClass="LoadingItem" CommandArgument='<%# Eval("AB_NUMBER") %>'>Schedule</asp:LinkButton>
</Columns>
<Templates>
<cc1:ItemTemplate ID="dteTemplate" runat="server" TemplateID="currDayDateHeaderTemplate">
<Template>
<asp:LinkButton runat="server" CssClass="AssignmentButton" ID="lbtnCurrentDay" CommandName="ASSIGN_CURRENT"><%= currDay.ToShortDateString() %></asp:LinkButton>
</Template>
</cc1:ItemTemplate>
<cc1:ItemTemplate ID="dteTemplate2" runat="server" TemplateID="secondDayDateHeaderTemplate">
<asp:LinkButton runat="server" CssClass="AssignmentButton" ID="lbtnSecondDay" PostBackUrl="../ApplicationForms/ManagerInterface/WOScheduler.aspx"
CommandName="ASSIGN_TOMORROW"><%= currDay.AddDays(1).ToShortDateString() %></asp:LinkButton>
<cc1:ItemTemplate ID="dteTemplate3" runat="server" TemplateID="thirdDayDateHeaderTemplate">
<asp:LinkButton runat="server" CssClass="AssignmentButton" ID="lbtnThirdDay" PostBackUrl="../ApplicationForms/ManagerInterface/WOScheduler.aspx"
CommandName="ASSIGN_THIRD_DAY"><%= currDay.AddDays(2).ToShortDateString() %></asp:LinkButton>
<cc1:ItemTemplate ID="dteTemplate4" runat="server" TemplateID="fourthDayDateHeaderTemplate">
<asp:LinkButton runat="server" CssClass="AssignmentButton" ID="lbtnFourthDay" PostBackUrl="../ApplicationForms/ManagerInterface/WOScheduler.aspx"
CommandName="ASSIGN_FOURTH_DAY"><%= currDay.AddDays(3).ToShortDateString() %></asp:LinkButton>
<cc1:ItemTemplate ID="dteTemplate5" runat="server" TemplateID="fifthDayDateHeaderTemplate">
<asp:LinkButton runat="server" CssClass="AssignmentButton" ID="lbtnFifthDay" PostBackUrl="../ApplicationForms/ManagerInterface/WOScheduler.aspx"
CommandName="ASSIGN_FIFTH_DAY"><%= currDay.AddDays(4).ToShortDateString() %></asp:LinkButton>
<cc1:ItemTemplate ID="dteTemplate6" runat="server" TemplateID="sixthDayDateHeaderTemplate">
<asp:LinkButton runat="server" CssClass="AssignmentButton" ID="lbtnSixthDay" PostBackUrl="../ApplicationForms/ManagerInterface/WOScheduler.aspx"
CommandName="ASSIGN_SIXTH_DAY"><%= currDay.AddDays(5).ToShortDateString() %></asp:LinkButton>
<cc1:ItemTemplate ID="dteTemplate7" runat="server" TemplateID="seventhDayDateHeaderTemplate">
<asp:LinkButton runat="server" CssClass="AssignmentButton" ID="lbtnSeventhDay" PostBackUrl="../ApplicationForms/ManagerInterface/WOScheduler.aspx"
CommandName="ASSIGN_SEVENTH_DAY"><%= currDay.AddDays(6).ToShortDateString() %></asp:LinkButton>
</Templates>
<Behaviors>
<ig:Selection CellClickAction="Row"></ig:Selection>
</Behaviors>
<EmptyRowsTemplate>
<div style="text-align: center;">
No records returned.
</div>
</EmptyRowsTemplate>
</ig:WebDataGrid>
</ContentTemplate>
</asp:UpdatePanel>
</emcor:WebPanel>
The link buttons all get set from a textbox datepicker value. What am I missing here?
Hello
I have this problem since years. It occurs when using wdg_RowAdded client event. When i remove this event i can add my rows normally.
Have you some explanation about this
Hafid
We are still following your case.
Please feel fee to contact us if you need any further assistance with this matter.
Thank you for contacting us.
I have reviewed the provided code snippet and didn't notice something incorrect. Could you please try to isolate the issue in a sample and send it back to me, this will be highly appreciated.
