725
WHDG RowUpdating event not firing every postback
Yet another vexing WHDG issue.  I am working with 13.2 build 3028.
I have a page with two instances of WHDG; one is single-level, one has a child band.  Markup is below.  I've made the configuration of the two grids as similar as possible.
In both grids, I have a number of non-editable columns and one editable checkbox template column (on the parent in the parent/child grid).
I want to do manual CRUD, so I am handling the RowUpdating event for each one.
The single-tier grid works fine, firing RowUpdating for each modified row on every postback.  The parent/child grid, however, fires RowUpdate only on every second postback.  For wxample, I click a row to change the checked value (the data in the row switches to italics, so I know the grid sees the edit), then I click a button that does a post back, but RowUpdating doesn't fire.  Also, the row in the grid returns to it's original values.  If I click the checkbox again and cause a postback, the RowUpdating DOES fire.  Another edit and postback does NOT fire the event, then a fourth edit and postback DOES fire it, etc.
I know that the postback always rebinds the data to the grid, but it does exactly the same thing every time, so that shouldn't affect the RowUpdating.
I've done a lot of exploration on this and can't find what is happening.
Any suggestions on what could be causing this?
    <table ID="cfbResultsTable" class="resultsGrid" runat="server">
         <tr>
             <td style="width:10px">&nbsp;</td>
             <td>
                 <cc1:QueryResults ID="cfbResults" runat="server"
                     oneventbuttonclicked="loadTicketsResults_EventButtonClicked"
                     DateFormat="" Height="140px"
                     AutoGenerateBands="False" AutoGenerateColumns="False" oninitializerow="cfbResults_InitializeRow"
                     DefaultColumnWidth="90px" onrowupdating="cfbResults_RowUpdating"
                     oncustomsummarycalc="cfbResults_CalculateCustomSummary" Width="100%"
                     oncalculatecustomsummary="cfbResults_CalculateCustomSummary"
                     DataKeyFields="id">
                     <ClientEvents Initialize="queryCfbInitGrid" />
                     <GroupingSettings EmptyGroupAreaText="Drag a column header here to group by that column.">
                     </GroupingSettings>
                     <Behaviors>
                         <ig:SummaryRow Enabled="False" EnableInheritance="True" FormatString="{1}"
                             ShowSummariesButtons="False" EmptyFooterText="-x-">
                         </ig:SummaryRow>
                         <ig:ColumnMoving></ig:ColumnMoving>
                         <ig:ColumnResizing>
                         </ig:ColumnResizing>
                         <ig:EditingCore AutoCRUD="False" BatchUpdating="True">
                             <EditingClientEvents CellValueChanged="loadCFBsCellUpdate" />
                             <Behaviors>
                                 <ig:CellEditing>
                                     <EditModeActions MouseClick="Single" />
                                 </ig:CellEditing>
                             </Behaviors>
                         </ig:EditingCore>
                         <ig:Sorting SortingMode="Multi">
                             <SortingClientEvents ColumnSorted="queryCfbInitGrid" />
                         </ig:Sorting>
                     </Behaviors>
                 </cc1:QueryResults>
             </td>
         </tr>
     </table>
     <br />
     <table class="resultsGrid">
         <tr>
             <td>
                 <cc1:QueryResults ID="loadTicketsResults" runat="server"
                     onlinkbuttonclicked="loadTicketsResults_LinkButtonClicked"
                     AutoGenerateBands="False" AutoGenerateColumns="False" DateFormat=""
                     QueryDatasetId="0" QueryFilterId="0" SecurityAppDesc="" TotalRows="0" DefaultColumnWidth="90px"
                     Height="410px" DataKeyFields="id"
                     onrowupdating="loadTicketsResults_RowUpdating" Width="100%"
                     oncustomsummarycalc="loadTicketsResults_CalculateCustomSummary"
                     ShowCustomSummary="False" InitialDataBindDepth="-1"
                     oninitializerow="loadTicketsResults_InitializeRow"
                     oneventbuttonclicked="loadTicketsResults_EventButtonClicked" >
                     <Bands>
                         <ig:Band AutoGenerateColumns="False" DataKeyFields="id"
                             DefaultColumnWidth="90px" Key="ChildBand_0" Width="800px">
                         </ig:Band>
                     </Bands>
                     <ClientEvents Initialize="queryTicketInitGrid" />
                     </GroupingSettings>
                     <Behaviors>
                         <ig:ColumnMoving EnableInheritance="True"></ig:ColumnMoving>
                         <ig:ColumnResizing EnableInheritance="True"></ig:ColumnResizing>
                         <ig:EditingCore AutoCRUD="False" BatchUpdating="True" EnableInheritance="True">
                             <EditingClientEvents CellValueChanged="loadTicketsCellUpdate" />
                             <Behaviors>
                                 <ig:CellEditing EnableInheritance="True">
                                 </ig:CellEditing>
                             </Behaviors>
                         </ig:EditingCore>
                             ShowSummariesButtons="False">
                         </ig:SummaryRow>
                     </Behaviors>
                 </cc1:QueryResults>
             </td>
         </tr>
     </table>
