Hello ALL,
I am facing with an issue while paging in inner grid of Hierarchical Grid.
I bind the data on page load, here I store the data in a session.I am assigning the session data in page init while paging.
Here when I go to second page for outergrid, then I click on next page for inner grid, here I the data doesnot bind to the grid or ajax control does not load the grid again.
I am using Ajax control toolkit 3.5 and infragistics dll version 11.2.
Can any one please help me in fixing the issue.
Thanks in advance!!
Chaitanya Kumar
Hello Chaitanya,
I am following up to see if you can provide me with an isolated sample that reproduces this behavior.
Please let me know if I may be of further assistance with this matter.
Thank you for the update. It doesn’t have to be the page you are using that is confidential. It just has to be a sample that reproduces the issue. If it is an isolated sample it is usually better as it narrows down there the issue may be occurring.
Hi Mike,
Providing you the application solution which I am facing is not possible as its confidential.
Let me tem you that when I do paging for inner grid, I get Error: ASP.NET Ajax client-side framework failed to load.
Do you have any idea on fixing this issue, which would also fix my paging issue.
Thanks & regards,
Chaitanya
Thank you for the update. I have updated my sample to use 1019 of v11.2 I am still unable to reproduce this issue. Please provide me with an isolated sample that reproduces this issue. Note you will have to remove the styles and bin folder to attach it to the forums. Note, please also use the account you used to create this thread to update the thread.
Here the attachment attached related to the issue.
