HI,
I am getting these assembly errors on build:
Error 1 The type 'Infragistics.WebUI.Shared.ISmartCallbackRender' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics45.WebUI.Shared.v14.1, Version=14.1.20141.2011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. \\psf\Home\Documents\Visual Studio 2013\Reccelerator\Reccelerator\EventManagement\GlobalCalendar.aspx.designer.cs 31 74 Reccelerator Error 2 The type 'Infragistics.WebUI.Shared.IUltraLicensedComponent' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics45.WebUI.Shared.v14.1, Version=14.1.20141.2011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. \\psf\Home\Documents\Visual Studio 2013\Reccelerator\Reccelerator\EventManagement\GlobalCalendar.aspx.designer.cs 31 74 Reccelerator Error 3 The type 'Infragistics.WebUI.WebControls.SmartWebControl' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics45.WebUI.Shared.v14.1, Version=14.1.20141.2011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. \\psf\Home\Documents\Visual Studio 2013\Reccelerator\Reccelerator\EventManagement\GlobalCalendar.aspx.designer.cs 31 74 Reccelerator
Can I please send my webconfig or something to you to fix this issue? I'm going by the youtube video Get Started with the Web Schedule Control.
https://www.youtube.com/watch?v=X0pua3Riy78&list=PLDAFFE8C757FED32E&index=21
NK
I am getting this error when i click button Object reference not set to an instance of an object in System.String EncodeColumnName(System.String) Method. I am using Infragistics4.Web.v14.1. Can you please tell me what is the exact reason behind this ? This was working fine with earlier version of IG controls.
Please see my post below.
I continue to see the errors when in design view at 11:05 in the tutorial:
Error 7 The type 'Infragistics.WebUI.Shared.ISmartCallbackRender' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics45.WebUI.Shared.v14.1, Version=14.1.20141.2011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. \\psf\Home\Documents\Visual Studio 2013\Reccelerator\Reccelerator\Schedules\MainSchedules.aspx.designer.cs 31 74 Reccelerator Error 8 The type 'Infragistics.WebUI.Shared.IUltraLicensedComponent' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics45.WebUI.Shared.v14.1, Version=14.1.20141.2011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. \\psf\Home\Documents\Visual Studio 2013\Reccelerator\Reccelerator\Schedules\MainSchedules.aspx.designer.cs 31 74 Reccelerator Error 9 The type 'Infragistics.WebUI.WebControls.SmartWebControl' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics45.WebUI.Shared.v14.1, Version=14.1.20141.2011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. \\psf\Home\Documents\Visual Studio 2013\Reccelerator\Reccelerator\Schedules\MainSchedules.aspx.designer.cs 31 74 Reccelerator
--and other errors I'm seeing for the controls are "Error Creating Control" for each one. I have added the references in the web config like you suggested. I want to buy this suite but I cannot get it to work... Any ideas would be appreciated.
I will be trying this out tonight.
Hi Noah,
Looking forward to hearing from you with the results.
