I want to use the WebHtmlEditor in a FormView.
The html is bound to the Text property of the editor.
<ighedit:WebHtmlEditor ID="ctlEditInfoPubliekHtml" Text='<%# Bind("HtmlInfo") %>' runat="server" Width="500px" SkinID="klein" UploadedFilesDirectory="~/Test">
Everything works fine except the 'insert image' button.
When using the editor outside the EditItemTemplate it works fine, but when using it inside the template I get the same formview in the popup window when using the image button.
I've narrowed the scope to a small aspx with one formview and the editor in the EditItemTemplate, so it should not be to difficult to reproduce.
Im using version 7.1.20071.1045
I was able to fix the problem.
I made a changed to the javascript of the modalpopup-extender.
In ModalPopupBehavior.js Line 126
this._foregroundElement.style.zIndex = $common.getCurrentStyle(this._backgroundElement, 'zIndex', this._backgroundElement.style.zIndex) + 1;
change to
this._foregroundElement.style.zIndex = parseInt($common.getCurrentStyle(this._backgroundElement, 'zIndex', this._backgroundElement.style.zIndex)) + 1;
This results in the generation of a background div with 10000 and a forground div of 10001 in stead of 100001.
The z-index of all WebHtmlEditor divs are arond 100000, so they are showed.
I will enter a change request for the WebHtmlEditor to add a base z-index property in case someone wants to add it onto divs with a z-index above 100000
Sting said:On a sidenote: Why couldn't I find the thread you posted in the forum?
Right... filteroptions only show post from last 2 months.
Default setting at 1 year would reduce re-posts like this I think.
jazpur said:I think you'll have to stick with your popup solution because the editor doesn't work correctly inside formview (or other controls that don't render the editor at page load). http://forums.infragistics.com/forums/p/1388/24333.aspx
It looks that way.
I had similar response from support.
Issue wil not be fixed.
But at this moment the popup route is no option because of the problems with the z-index.
I've entered a support request about this.
