i want to edit the password for a particular user. i have created a page for it where i have 3 webimage buttons namely, cmdEdit,cmdSave,cmdCancel. when the a user click on the cmdEdit button, the cmdSave and cmdCancel should be visible. i want to do it in the javascript. i already have written the code for it.. please find the script below
function cmdEdit_Click(oButton, oEvent){ var savebutton = ig_getWebControlById("cmdSave");
var cancelbutton= ig_getWebControlById("cmdCancel"); oButton.setVisible(false);
savebutton.setVisible(true); cancelbutton.setVisible(true); }
i have disabled the cmdSave and cmdCancel inthe page_load event in the server-side.the problem i face is that the cmdEdit button gets invisible and the rest is not working. can someone tell me what could be the problem?
thanks
jollyguy77
Is your browser giving you a "null reference not found" javascript exception?
Your code is setting the
jollyguy77 said: var savebutton = ig_getWebControlById("cmdSave"); [snip]savebutton.setVisible(true);
[snip]
If you set the Visible to false on the server, then ASP.Net isn't going to send down the html for the control. Same happens with a default control if I am not mistaken.
You would need to send the control down with Visible = true and set Visible = false on the client.
