2211
Blank image beeing added on postback.
Hello again everyone,
 I have found another problem when using the imageviewer control:
Pressing the browser refresh button after page load causes a blank image to be inserted into the image viewer or one or more of the images does not render.
Case 2 images in the viewer.
Reresh page.
blank image in viewer, scroll left or right... wala the images show up and the control removes the blank space.  What is going on here?
Code
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
If Not IsPostBack Then
Dim dbl_GoalOne As Double
Dim dbl_MileStone As Double
Dim dbl_CurrentSales As Double
Dim str_GoalTitle As String = ""
Dim str_MileStoneTitle As String = ""
Dim dt_LastUpdate As DateTimeDim ds As DataSet = New DataSet
ds = get_CurentSalesTotalandGoals()
If Request.Browser.Type.ToString.Contains("Firefox") Then
wiv_Main.StyleSetName = "RubberBlack"
wiv_Main.StyleSetPath = "~/ig_res"
End If
If Not ds.Tables.Count = 0 Then
dbl_GoalOne = ds.Tables("TableName").Rows(0).Item("DataField")
str_GoalTitle = ds.Tables("TableName").Rows(0).Item("DataField")
set_GoalOne(dbl_GoalOne, str_GoalTitle, ds.Tables("TableName").Rows(0).Item("DataField"))
If Not ds.Tables("TableName").Rows(0).Item("DataField") Is System.DBNull.Value Then
dbl_MileStone = ds.Tables("TableName").Rows(0).Item("DataField")
str_MileStoneTitle = ds.Tables("TableName").Rows(0).Item("DataField")
set_MileStone(dbl_MileStone, str_MileStoneTitle, ds.Tables("TableName").Rows(0).Item("DataField"))
Else
Hide_MilestoneMarker()
End If
dbl_CurrentSales = ds.Tables("TableName").Rows(0).Item("DataField")
set_CurrentSalesMonthly(dbl_CurrentSales, dbl_GoalOne)
set_CurrentSalesQuarterly(dbl_CurrentSales, dbl_MileStone)
Else
End If
dt_LastUpdate = ds.Tables("TableName").Rows(0).Item("DataField")
End If
Else
lbl_User_Messages.Visible = True
lbl_User_Messages.Text += " :The data was not retrived from the DataBase."
End If
wiv_Main.Items.Add(New Infragistics.Web.UI.ListControls.ImageItem("~/GaugeImages/GuageMonthly.png", "SomeText", "SomeText"))
wiv_Main.Items.Add(New Infragistics.Web.UI.ListControls.ImageItem("~/GaugeImages/GuageQuarterly.png", "SomeText", "SomeText"))
'Else  'This code is not fixing the problem
' wiv_Main.Items.Add(New Infragistics.Web.UI.ListControls.ImageItem("~/GaugeImages/GuageMonthly.png", "Some Text", "Some Text"))
' wiv_Main.Items.Add(New Infragistics.Web.UI.ListControls.ImageItem("~/GaugeImages/GuageQuarterly.png", "Some Text", "Some Text"))
End If
End Sub
Any solutions?
Patrick
