165
URGENT. Help require for WebUpload control in WedDialogWindow inside an UpdatePanel.
I am currently using Infragistics35 2012 v12.1 with VS2008.
Can anyone provide a simple sample solution for a WebUpload infragsitic control inside a WebDialogWindow?? The WebUpload samples on the infragistics web is simply difficult to utilize, most of the JS scripts cannot be found.
Please help ASAP.
Thank you in advance,
cno
  • 15320
    Suggested Answer
    Hello chinho,
    I've created a sample that demonstrates WebUpload inside of WebDialogWindow control as per your requirement. Note that in order the WebUpload to work properly you should include the required javascript and css files on your .aspx page, which by default are located in C:\Users\Public\Documents\Infragistics\NetAdvantage 20XX.X\ASP.NET\Samples\Infragistics.Web.AspNET\SamplesCommon\aspnet\Common directory. Here is also a link from our documentation that goes through WebUpload Overview for your reference: http://help.infragistics.com/Help/Doc/ASPNET/2011.1/CLR4.0/html/WebUpload_Overview.html
    If you have any further questions, please let me know.
    Sincerely,
    Tsanna
    InsideWDW.zip
