HI
We are facing IE 10 crashing issues after using infragistic controls version 13.1 and visual studio 2012.Can anyone give the solution for this post.am attaching the screen shot for the issues. Hope for reply to this post with solution.
Thank you
Hello Shah,
I am still following your case and I was wondering did you manage to resolve your issue?
Please do not hesitate to contact me if you are still in need of assistance.
Thank you for your patience.
I was unable to successfully open the attached website in VS 2012 in order to search for the root cause of this behavior. Opening the sample in VS2010 works, however examining the code it appears that due to the size of the files and amount of custom logic implemented, debugging this solution would not be possible.
Providing me with isolated, simplified version, which is ready-to-run where this issue is reproducible would be highly appreciated and would help me with addressing the issue correctly.
Thank you very much for your cooperation on this matter.
Thank you very much for providing me the sample project.
I am still looking into your code. I will need some additional time to investigate further and find the root cause for your issue.
Please feel free to continue sending updates to this case at any time.
Thank you for you patience and cooperation on this matter.
Hi
Am attaching for you the webpages,web config and dll files we used in our project please check and reply as back, we are waiting for the issue to be solved asap.
Thank You!!!
Hello Kushagra,
Thank you for your sample.
In order to run the sample and reproduce the issue on my side I will need all the dll files used in the application. Could you please provide with all the necessary dll files, as well as your web.config file and any custom classes if you have any.
Additionally, some steps to reproduce will ensure that I will follow the same scenario as yours in order to reproduce the described behavior.
Thank you for your cooperation on this matter.
