Hi
We have purchased NetAdvantage for ASP.NET. We have been building an application using version 13.1.20131.2107, making use of the Schedule control. We have dropped this control into our own UserControl and are deploying this to SharePoint 2013.
We upgraded to 13.1.20131.2157 we started getting the following error in SharePoint for the same control.
We have an deployment for UAT this weekend and we need to get back to 2107 so we have a stable build. Is there any way to uninstall the current version and re-install the 2107?
Best Regards,
Arnie
Attempt by security transparent method 'Infragistics.WebUI.Shared.Util.ScriptManager.Init(System.Web.UI.Page)' to access security critical method 'System.Web.UI.ScriptManager.GetCurrent(System.Web.UI.Page)' failed.Assembly 'Infragistics45.WebUI.Shared.v13.1, Version=13.1.20131.2157, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' is marked with the AllowPartiallyTrustedCallersAttribute, and uses the level 2 security transparency model. Level 2 transparency causes all methods in AllowPartiallyTrustedCallers assemblies to become security transparent by default, which may be the cause of this exception.Assembly 'System.Web.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' is a conditionally APTCA assembly which is not enabled in the current AppDomain. To enable this assembly to be used by partial trust or security transparent code, please add assembly name 'System.Web.Extensions, PublicKey=0024000004800000940000000602000000240000525341310004000001000100B5FC90E7027F67871E773A8FDE8938C81DD402BA65B9201D60593E96C492651E889CC13F1415EBB53FAC1131AE0BD333C5EE6021672D9718EA31A8AEBD0DA0072F25D87DBA6FC90FFD598ED4DA35E44C398C454307E8E33B8426143DAEC9F596836F97C8F74750E5975C64E2189F45DEF46B2A2B1247ADC3652BF5C308055DA9' to the the PartialTrustVisibleAssemblies list when creating the AppDomain.
I'm also getting this error on version 15.1.20151.1018 is there a fix for this?
Hello Arnie,
I have created a private support case for you regarding this matter - CAS-127040-C7X3S7 and will send you instructions on how downgrading can be achieved in this scenario. Please do not hesitate to contact me if you continue to experience any issues.
Thank you for choosing Infragistics.
