240
UserControl as rowedittemplate for child band; issues with loading & binding
Infragistics4.Web.v13.1, Version=13.1.20131.2107
I'm trying to utilize a usercontrol as the rowedittemplate for a childband in my WHDG. The idea behind the UC is that it should dynamically represent the data being edited: different controls will be visible for different data in the bands.
Q/P1): is there a way to prevent the UC from being rendered with every childband record? There could be 1000's...
Q/P2): how do I bind serverside to some public properties of the UC? Since it appears the UC instances are loading with every record (see above), I could cut down on the amount of html being rendered by only making visible the controls I am concerned with for each row. Using two public properties "Parameter" and "Selections", I have tried this type of setup in the template:
<ig:RowEditingTemplate CancelButton="buttonCancel" OKButton="buttonOK">
<Template>
<uc1:ucSetParameter ID="ucSetParameter1" runat="server" Parameter='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "ParameterName") %>' Selections='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "CurValue2") %>' />
</Template>
</ig:RowEditingTemplate>
but cannot determine the correct binding container reference, I either get "not part of namespace" or "doesn't contain this property" errors (I've confirmed the dataset does match the "ParameterName" key & case) whenever I try alternate container references.
Any help appreciated.
