2235
how to prevent focus on a cell?
I have a webdatagrid, it has a number of columns, 2 are editiable, the rest are read only...
When selection is turned on, pressing  tab puts focus on the readonly cells, i would like to prevent this from happening and only "tab" to the editable cells.
Some help?
  • 49378
    Verified Answer
    Hello Daryl007,
    I am attaching a sample illustrating how activation may be skipped (disabled) for readonly cells in a grid allowing tabbing through only the editable cells. Note that this scenario also sets the focus on the nearest editable cell, once a readonly cell is clicked. Below is the relevant javascript code used:
    function WebDataGrid1_Activation_ActiveCellChanging(sender, eventArgs)
        //if you click on the non editable cell, cancel the event and return so nothing happens
        if (typeof event != 'undefined'  && event.type == "mousedown" && eventArgs.getNewActiveCell().get_column().get_key() == "SupplierID") {
            eventArgs.set_cancel(true);
            return;
        var column = eventArgs.getNewActiveCell().get_column();
        var columnKey = column.get_key();
        var cellEditing = sender.get_behaviors().get_editingCore().get_behaviors().get_cellEditing();
        var columnSetting = cellEditing.get_columnSettingFromKey(columnKey);
        if (columnSetting != null && columnSetting.get_readOnly()) {
            var cellIndex = eventArgs.getNewActiveCell().get_index();
            //logic to jump over multiple readonly cols
            var nextCell = eventArgs.getNewActiveCell().get_row().get_cell(cellIndex + 1);
            var nextCellKey = nextCell.get_column().get_key();
            while (cellEditing.get_columnSettingFromKey(nextCellKey)) {
                nextCell = nextCell.get_row().get_cell(nextCell.get_index() + 1);
            sender.get_behaviors().get_activation().set_activeCell(eventArgs.getNewActiveCell().get_row().get_cell(nextCell.get_index()))
    	//Add code to handle your event here.
    Hope this helps. Please do not hesitate to contact me if you have any questions.
    WebDataGridNavigationSkipNonEditable (3).zip
