Dear All,
I have been trying to install NetAdvantage Infragistics 2005 Vol. 1 on Windows Server 2008 (64bits) and got an error message “Error 1606. Could not access network location %SystemDrive%\Inetput\wwwroot\”. I try to fix this problem by changing from the registry key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\InetStp -> PathWWWRoot value to C:\inetpub\wwwroot”. After doing this it doesn’t solve my problem it remains the same error. Need your help.
Kind regards,
Suan Ngaihte
Thanks, It works.
I believe on 64 bit machines there is another node that needs to be modified. You may have to do the same for HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\InetStp\PathWWWRoot.
Please note that 2007 Volume 1 is the first volume that supports 64 bit systems and 2008 Volume 2 will probably be the first volume that supports windows server 2008.
KB on 64 bit support:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10005
Forum post on Windows Server 2008 support:
http://forums.infragistics.com/forums/p/8122/32515.aspx#32515
