Hi
I am new to this control and trying to setup the schedule. My table schema is not the same as default schema of this control. the table contains the following fields: Duedate, Currentdate, Description and subject.
I added webscheduelinfo, webscheudleoledbprovider and webmonthview. when i run the program, i can not see any data in m schedule.
Can you please help?
Kamal
I have created the tables myself. Does it mean that the schema should be the same? I like to display data and may like to add/update them if its required.
I have a table with the following fields:
ID, Description, Subjects, Fullyear, Monthno, Weekno, DueDate, GenDate, and iscomplete.
Fullyear, Monthno and weekno are not used for webscedule.
Hi Kamal,
Have you created the tables ur own or run the script? See if you require the mentioned fields then add them but if you want to add/ update/display in webmonthview or any you need to have those tables.
If you are still not satisfied then put ur details abut wat tables u have or created.
