I'm creating the webdatagrid by binding datatable with one row witch becomes header.
I have the DefaultColumnWidth set and it works for all columns.
What I want to do is set a different column width for different columns.
But the webdatagrid says it has no rows nor columns.
It begins like this:
WebTableControl.DataSource = table WebTableControl.DataBind()
WebTableControl.DefaultColumnWidth = 150 TableControlBase.getViewState("table") = table
Than what I've tried to do is:
1:
WebTableControl.Rows(0).Items(7).Column.Width = 400
WebTableControl.Rows(0).Items(6).Column.Width = 100
2:
WebTableControl.Columns("column name").Width = 400 WebTableControl.Columns("column name 2").Width = 200
3:
For Each igrow As Infragistics.Web.UI.GridControls.GridRecord In WebTableControl.Columns
Next
None of those seems to work.
After adding a row what does work is this:
Protected Sub ApplyFieldSettings_InitializeRow(sender As Object, e As Infragistics.Web.UI.GridControls.RowEventArgs) Handles WebTableControl.InitializeRow.......
Dim IGRow As Infragistics.Web.UI.GridControls.GridRecord = e.Row
But not on a empty webdatagrid.
Any suggestions?
Found a solution maybe someone will need it.
I've just added a row to the table (any row) binded table to webdatagrid, then removed the row and binded again.
Thanks to that the initializerow event fired and the webdatagrid keept the columns width set in the event.
