1605
UltraWebGrid 2010.3 slow performance when adding row totals
I have an ASP.Net 3.5 application using the Ultrawebgrid to enter timesheet hours. I know that IG has stopped supporting the uwg but I am stuck at the moment trying to decide on when to upgrade to the newer controls (we would normally invest in technologies supported more than 5 years), but I hope somebody seeing this might offer a helping hand; it will surely be greatly appreciated.
Anyhow when the user updates a cell in the grid, a loop is executed (javascript) which adds the column's entries and updates the totals row for that column. The loop is in the shown below:
function grdTimeSheet_AfterCellUpdateHandler(gridName, cellId) {
var grid1 = igtbl_getGridById(gridName);
var cell1 = igtbl_getCellById(cellId);
var cellIndex = cell1.Column.Index;
var RowsCounter = grid1.Rows.length;
//Calculate the new column total and update the totals rows.
var SubTotal1 = 0;
for (c = 0; c < RowsCounter - totalStaticRows; c++) {
//var row1 = grid1.Rows.getRow(c);
var cellValue = grid1.Rows.getRow(c).getCell(cellIndex).getValue();
if (cellValue != null)
var val = parseFloat(cellValue);
        if (isNaN(val))
             row1.getCell(cellIndex).setValue(0);
             val = parseFloat(0);
        SubTotal1 = SubTotal1 + val;
var TotalChargeableRowIndex = RowsCounter - totalStaticRows;
grid1.Rows.getRow(TotalChargeableRowIndex).getCell(cellIndex).setValue(SubTotal1);
As the number of rows on the grid becomes larger, there is a delay becoming more and more prominent the first time the user updates a cell on a row. After typing the value and hitting tab there is a delay (as long as 40-60 seconds for a grid of 60 rows!) until the focus falls on the next cell. Changing the contents of other cells in the same row is thereafter 1 second fast. Adding a new line to the grid and trying to type on it again gives the same problem.
Can somebody explain what the problem might be? Am I doing something wrong? It seems to me like each time a row cell is accessed the first time, the getRow function used above takes a long time to load the row objects in memory and thereafter keeps them somehow cached somewhere until a cell in a new row is accessed at which case the loading takes place again.
Is there an alternative way of reading the values of the cells in a column from row a to row b and add them up?
