I'm having so much problems concerning one thing that I thought it was very simple, so let me explain in few words....
I need to generate pdf bills for different customers, with different template of bills. They want to give me pdf files with their own templates and appearence, which I will use after for generating their bills.
Cannot find anywhere a way to use templates, neither in infragistics.Documents.Report library nor in .NET libraries.
I'^m lost and don't know what to say to my boss.
It seems like if nobody ever had the same problem.
Please help me, I can't find a way to do that :
template.pdf + infragistics.documents.reports data generation = bill.pdf
Thank you so much.
Michael.
As Petar said, the Infragistics document library does not support the loading of reports from pdf files directly. And as suggested, guess you may firstly save as XML and then convert XML into PDF file. Or maybe integrate a .NET PDF creation library into your project for PDF generation.
Hello Michael,
The Infragistics Document library currently does not support the loading of reports from pdf files directly. For reports created with the engine, it is possible to save them as XML which may then be used for reloading. The functionality for loading PDFs directly has therefore been determined to be a new product idea.
You can suggest new product ideas for future versions (or vote for existing ones) at <http://ideas.infragistics.com>.
There are many benefits to submitting a product idea:
- Direct communication with our product management team regarding your product idea.
- Notifications whenever new information regarding your idea becomes available.
- Ability to vote on your favorite product ideas to let us know which ones are the most important to you. You will have ten votes for this and can change which ideas you are voting for at any time.
- Allow you to shape the future of our products by requesting new controls and products altogether.
- You and other developers can discuss existing product ideas with members of our Product Management team.
Steps to create your idea:
1. Log into the Infragistics Product Idea site at http://ideas.infragistics.com (creating a new login if needed).
2. Navigate to the product / platform channel of your choice (e.g. WPF, Windows Forms, ASP.NET, HTML5 / Ignite UI, iOS / NucliOS, etc.)
3. Add your product idea and be sure to be specific and provide as much detail as possible. Explain the context in which a feature would be used, why it is needed, why it can’t be accomplished today, and who would benefit from it. You can even add screenshots to build a stronger case. Remember that for your suggestion to be successful, you need other members of the community to vote for it. Be convincing!
The Product Idea site puts you in the driver’s seat and allows you to track the progress of your ideas at any time, see how many votes it got, read comments from other developers in the community, and see if someone from the product team has additional questions for you.
Thank you for contacting Infragistics.
At least can I use the save() method included in the report library to save a pdf file that was not created by the infragistics engine, so I can re use it as a template ?
If possible, how can I manage it ?
Thanx for every suggestion.
Michaël.
