20
WebDatePicker Client ID
Hello
I am using the WebDatePicker control, and the date picker text box renders like:
<input title="" class="igte_EditInContainer" id="x:2036271367.0:mkr:3" style="width: 98%; height: 100%; float: left; ime-mode: disabled;" type="text" alt="" mkr="3"/>
All what i need is to have a way to change the generated client ID of this control.
is there anyway to change it?
  • 24497
    Hi Wesam,
    The value of that id is generated by server and it has special internal format, which allows to find that element on client. On client that id is used only while initialization and I think that after internal variables are intialized, then id probably can be modified.
    If you ask about changing that id on server before html is generated, then it is not possible. If you ask about changing that id on client, then you may use something like below:
    function WebTextEditor1_Initialize(sender, eventArgs) {
    sender.get_inputElement().id = 'myCustomUniqueID';
    </script>
    <ig:WebTextEditor ID="WebTextEditor1" runat="server">
    <ClientEvents Initialize="WebTextEditor1_Initialize" />
    </ig:WebTextEditor>
