I have an application that has parent and child tables. The user selects a shipping terminal and clicks GO to display a list of workers and their information. The hierarchy goes down three levels. Terminal Summary - Worker Summary - Worker Detail. The application always works fine on the first pass. But when the user changes terminals the application always returns the following error "Table (tablename) doesn't contain a row with the specified PrimaryKey value" on the following line of code:
whdg.ExpandAll()
Any help will be greatly appreciated.
Do you still need help with this issue?
Olga
Hi Joseph,
Are you changing the WHDG’s datasource when the user picks a new terminal?
If you are not changing the datasource try calling Clear() on the GridView’s Rows, right before you assign a new datasource. Whdg.GridView.Rows.Clear(); That may fix the issue. If that does not fix the issue you are seeing, can you provide a small sample that functions similarly to your application (using some made up datasources).
Thank You,
ASP.NET Principal Software Engineer
Infragistics, Inc.
