1965
cannot use webdatetimeditor inside ultrawebgrid..help!!!!!!!urgent
I am trying to upgrade from WebDateTimeEdit to WebDateTimeEditor and I get this error. What is a possible solution?
The control WebDateTimeEditor1 references a control that does not implement IProvidesEmbeddableEditor and cannot be used as the editor control for column MyGrid_c_0_6
  • 24497
    WebDateTimeEditor is AJAX (implementes IScriptControl) control and it is not compatible with UltraWebGrid.
    Usage of WebDateTimeEditor would require presence of ScriptManager and all other quite heavy stuff in your application which is not required by UltraWebGrid.
    If you have WebDateTimeEditor, then you also have WebDataGrid, because it is located in same dll. I suggest you consider replacing UltraWebGrid by WebDataGrid. In this case DateTime-cell editors will be WebDateTimeEditor and other editors (numeric, etc.) will be from same dll too.
