I have an issue with the WebDatePicker. It maybe that I am not configuring it correctly. I used StyleSetPath and the images that make the calendar appears work properly. But the images within the calendar itself, such as the previous and next image, doesn't use the path I specified in StyleSetPath. It is still going to the "ig_res/default/..." folder. Is this a bug in NetAdvantage v12.1? Or, is there a different setting for those images?
Thank you,
Trent
Hi tnguyen13,
Thank you for sharing your solution with the Infragistics Community.
I found a way around this. I just updated my web.config and added the section name "infragistics.web"
<section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<infragistics.web styleSetName="Default" styleSetPath="~/images/infragistics"/>
Hi Trent,
This is an initial update to let you know that I have received your inquiry. I will be looking into this matter for you and will follow-up regading the status of my research on or before Monday.
