3550
Chart with updatepanel
I have a chart and an updatepanel.
I load the chart data first time the form loads.
When I press the button, I expect the chart data to stay the same, since it is not on the updatepanel.
I only want the updatepanel to refresh.
But the chart give the warning: Data not available ...
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using Infragistics.UltraChart.Shared.Styles;
using System.Data;
namespace WebApplication11
    public partial class WebForm2 : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
            if (!IsPostBack)
                UltraChart1.ChartType = ChartType.ColumnChart;
                DataTable columnData = new DataTable("ColumnData");
                columnData.Columns.Add("Month", typeof(string));
                columnData.Columns.Add("Foo", typeof(double));
                columnData.Columns.Add("Bar", typeof(double));
                //Add additional columns here; for each column add a parameter to each row below.
                //Below uses params so additional columns of data are comma delimited
                columnData.Rows.Add("Jan"/*Month*/, 3400/*Foo*/, 1200/*Bar*/ /*, YourNewColumn*/);
                columnData.Rows.Add("Feb", 2300, 1200);
                columnData.Rows.Add("Mar", 5994, 1200);
                UltraChart1.DataSource = columnData;
                UltraChart1.DataBind();
                Label1.Text = "xx";
        protected void Button1_Click(object sender, EventArgs e)
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="WebForm2.aspx.cs" Inherits="WebApplication11.WebForm2" %>
<%@ Register Assembly="Infragistics4.WebUI.UltraWebChart.v12.2, Version=12.2.20122.2054, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI.UltraWebChart" TagPrefix="igchart" %>
<%@ Register assembly="Infragistics4.WebUI.UltraWebChart.v12.2, Version=12.2.20122.2054, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.UltraChart.Resources.Appearance" tagprefix="igchartprop" %>
<%@ Register assembly="Infragistics4.WebUI.UltraWebChart.v12.2, Version=12.2.20122.2054, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.UltraChart.Data" tagprefix="igchartdata" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
</head>
<body>
    <form id="form1" runat="server">
    <asp:ScriptManager ID="ScriptManager1" runat="server">
    </asp:ScriptManager>
    <asp:UpdatePanel ID="UpdatePanel1" runat="server">
        <ContentTemplate>
      <igchart:UltraChart ID="UltraChart1" runat="server"
                EmptyChartText="Data Not Available. Please call UltraChart.Data.DataBind() after setting valid Data.DataSource"
                Version="12.2">
        </igchart:UltraChart>
        <asp:Label ID="Label1" runat="server" Text="Label"></asp:Label>
        </ContentTemplate>
            <Triggers>
            </Triggers>
    </asp:UpdatePanel>
    <asp:Button ID="Button1" runat="server" Text="Button" onclick="Button1_Click" />
     <asp:UpdatePanel ID="UpdatePanel2" runat="server">
        <ContentTemplate>
        </ContentTemplate>
            <Triggers>
                <asp:AsyncPostBackTrigger ControlID="Button1" EventName="Click" />
            </Triggers>
    </asp:UpdatePanel>
    <div>
    </div>
    </form>
</body>
</html>
  • 17559
    Verified Answer
    Hello drpoalim,
    Our WebChart requires rebinding on every postback, so I could suggest you modify your Page_Load method like this:
            Label1.Text = "xx";
    Please let me know if this helps.
