I am trying to save the visibleindexes of columns on a WebDataGrid. In my WebDataGrid, I have the the following tags set
<ig:Sorting Enabled="True"></ig:Sorting> <ig:ColumnMoving Enabled="True" /> <ig:ColumnResizing Enabled="True"></ig:ColumnResizing>
and everything works fine. I would able to drag any columns on the datagrid and move them to different position. I would be able to resize columns, and choose different sorting. The problem is that the properties of the columns do NOT change.
I have trapped event PreRenderComplete() and try to save the WebDataGrid. But the main problem is that the properties of the columns do not change. No matter what I do, the visibleindex and the width properties of columns stay the same.
Please advise.
Thanks.
This is in my aspx file.
<ig:WebDataGrid ID="WebDataGrid1" runat="server" Width="100%" ClientEvents-DoubleClick="webDataGrid_DblClick1" OnInitializeRow="WebDataGrid1_OnInitializeRow" OnRowSelectionChanged="WebDataGrid1_OnRowSelectionChanged" AutoGenerateColumns="false" EnableDataViewState="True" DefaultColumnWidth="100"> <Behaviors> <ig:Selection RowSelectType="Single" CellClickAction="Row" > </ig:Selection> <ig:Paging PagerAppearance="Top" PagerMode="NumericFirstLast" QuickPages="3" PageSize="10" FirstPageText="First" LastPageText="Last"> </ig:Paging > <ig:RowSelectors > </ig:RowSelectors> <ig:Sorting Enabled="True"></ig:Sorting> <ig:ColumnMoving Enabled="True" /> <ig:ColumnResizing Enabled="True"></ig:ColumnResizing> </Behaviors> </ig:WebDataGrid>
The VisibleIndex is still always -1 with the latest release (15.1)
Hello DQ ninh,
Did you have the chance to download the latesr service release?
Can you confirm that the issue has been resolved with it?
Please let me know when you test this.
I'm experiencing the same issue. VisibleIndex begins as and is always -1. Please provide updated information when you have it.
I have investigated your isuue and I have asked our engineering staff to examine this further. To ensure that it will recieve attention, I have logged this behavior in our internal tracking system with a Development ID of 136473. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix or other resolution.I have created a support ticket for you. The number of tha case is CAS-112445-Q9W1H7. You can continue to send updates to this case at any time. You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the website.
Please let me know if you need more information.
