190
WebScheduleInfo control - OnActivityUpdating not calling the target server method
I have the following WebScheduleInfo control in an ascx file.  The datAppointments_ActivityUpdating method as targeted for the OnActivityUpdating doesn't get called in the code behind for some reasons after the activity has been moved to a different time slot on the calendar.  It was working in v7.2, but it no longer does after I upgraded the app to v12.1.
Anyone else having the same issue or having a fix/workaround for this issue?
Calendar.ascx:
<ig_sched:WebScheduleInfo ID="datAppointments" runat="server"
    FirstDayOfWeek="Monday"
    AllowAllDayEvents="True"
    EnableReminders="False"
    WorkDayStartTime="7:00"
    OnActivityUpdating="datAppointments_ActivityUpdating"
    EnableSmartCallbacks="True">
</ig_sched:WebScheduleInfo>
Calendar.ascx.cs:
    protected void datAppointments_ActivityUpdating(object sender, CancelableActivityEventArgs e)
        try
            String jobRequestId = e.Activity.Key.ToString();
            DateTime newStartDate = DateTime.Parse(e.Activity.StartDateTime.ToString());
            int newDuration = Convert.ToInt32(e.Activity.Duration.TotalMinutes);
            JobRequestService service = new JobRequestService();
            service.Reschedule(jobRequestId, newStartDate, newDuration);
        catch (Exception exception)
            ExceptionHandler.LogWebApplicationException(exception);
