I would like to use different styling for the separators, such as a different character, image, or make them wider, taller, shorter, etc. It looks like the styles are rendered inline and changing the styles in the ig_res folder don't seem to affect them all the time. For instance, I cannot even make the default horizontal separator wider by changing the width in the igdm_Windows7MenuItemHorizontalSeparator class.
Hello, AnthonyPlease let me know if you have any further questions regarding this issue.
Hello Anthony,Please take a look at the attachment. It may be necessary to force the width and height properties with !important to take effect. I would also advice you not to modify our classes directly but use a “custom.css” file in which you are modifying the necessary classes like I did in the sample and just add reference to it in the pages which are about to use the modifications.
