45
Calling Columns.Clear results in dynamically added columns not rendering when paging
I have a multipurpose page that display all sorts of data sources in a WebDataGrid.
The grid has an unbound dynamically added WebDataGridCheckBox column added via a TemplateDataField in code.
The rest of the columns are created by adding BoundDataField objects to the Columns collection (nothing is defined declarative)
All works well, including paging, until I change the data source.
When switching data sources, I first call ClearDataSource and then Columns.Clear before recreating the unbound and then bound columns.
The new grid renders fine, however when paging, the Checkbox control disappears (although the header is still there).
If I do not call Columns.Clear the problem does not happen, however if the data sources have different columns in them, this causes a problem.
Can anyone help with this?
Code Snippets:
    Public Function Reset() As Boolean
        With Grid
            .ClearDataSource()
            .Columns.Clear()
            If Not IsNothing(.Behaviors.Sorting) Then Behaviors.Sorting.SortedColumns.Clear()
            If Not IsNothing(.Behaviors.Filtering) Then Behaviors.Filtering.ClearBehaviorColumnInfo()
            BuildColumns()
        End With
        Return True
    End Function
    Private Function BuildColumns() As Boolean
        Dim chkSel = Grid.Columns.FromKey("chkSel")
        If chkSel Is Nothing Then
            Dim chk As New WebDataGridCheckbox("chkSel")
            Dim tdf As New TemplateDataField(False)
            tdf.ItemTemplate = chk
            tdf.Key = chk.Key
            tdf.Width = New Unit(30)
            tdf.Hidden = Not ShowCheckbox
            Grid.Columns.Add(tdf)
        End If
        Return BuildDataColumns()
    End Function
