I have just installed the new infragistics 2008 volume 1 for ASP.Net.
I wanted to create a simple demo solution to see how the web splitter works and can be integrated in to our software.
I created a new web application solution in visual studio. I added the websplitter control from the toolbox and then started the application in debug mode to see if i at least get two empty panes. The solution builds with no errors. However i get the following problem are there any hints?
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately. Compiler Error Message: CS0426: The type name 'Default' does not exist in the type 'Infragistics.Web.UI.LayoutControls.WebSplitter'Source Error:
Line 118: public default_aspx() { Line 119: string[ dependencies; Line 120: ((WebSplitter.Default)(this)).AppRelativeVirtualPath = "~/Default.aspx"; Line 121: if ((global::ASP.default_aspx.@__initialized == false)) { Line 122: dependencies = new string[1];
Did you create an ASP.NET AJAX website? The splitter needs to be in an AJAX site where it can get to all the MS AJAX Scripts.
After install Infragistics 2008 Vol 1. CLR 2.0 .. I created a new web site solution, open the default aspx page and put into it the WebSplitter Control, everything goes fine, compilation but when the page shows up, there is a Javascript error and the control didn't work. When I clicked in the Javascript error icon it says that "Sys is not defined" ... What is that.. can everyone help me ???
as far as i know i only had a problem with this control. I am not sure if i installed something incorrectly or not, because i have previous versions of infragistics installed.
however my work around to this problem was to use a web site, instead of a web application and this seemed to work.
Andrew:
Are any other controls giving you this problem or is it only the splitter control?
