I have a webdatagrid with multi column header. Text in multicolumn header always align left in IE. How to make it align center.
Please help. Thank in advanced.
I have solved it. It is because of the compatibility view issue.
Go to IE Compatibility View Settings > uncheck Display all websites in Compability view and Display intranet sites in Compatibility View.
Thanks David,
I' m using Infragistics Default style sheet. And the GroupFieldHeaderCaption already align center as below:
.igg_GroupFieldHeaderCaption{ text-align: center; text-shadow: 1px 1px #fff; font-size: 10px;}
But it still align left.
It is exactly same with the example in Infragistics: Multi-Column headers with Column Fixing
When view with IE, the multi-column header align left. I think when merge 2 column together, the header will squeeze at fist column.
Hi syne,
You should set a css class on the header object that has text align center on it.
regards,
David Young
