I am currently using WebMonthView and WebScheduleInfo.
I am having an issue with the styling. I have the ig_res folder in the root directory. How do I correctly point my WebMonthView/WebScheduleInfo to the root directory which is located in root/MyProject. I have tried to hand type it, use the styling wizard in design view, using the properties. It seems when ever I change it all of the styling vanishes and it is void of all styles. I know I must be doing something incorrectly here I just can't seem to figure that out. Would like to link it up to all of the styles available with the control (Appletini etc) which are currently in the ig_res folder in the root directory.
<igsch:WebMonthView ID="cboLocations" runat='server' WebScheduleInfoID="WebScheduleInfo1" Style="top: 0px; left: -1px; height: 563px; width: 87%" StyleSetName="Office2010Blue" EnableMultiResourceCaption="True" Height="500px" MultiDayEventFromArrowCaption="" MultiDayEventToArrowCaption="" StyleSetPath="" StyleSheetDirectory="" Width="500px"> </igsch:WebMonthView> <igsch:WebScheduleInfo ID="WebScheduleInfo1" runat="server"> <ClientEvents ActivityDialogOpening="WebScheduleInfo1_ActivityDialogOpening" /> <ClientEvents ActiveDayChanging="WebScheduleInfo1_ActiveDayChanging" /> </igsch:WebScheduleInfo>
I'm just checking if you have resolved your issue.
Hi OmegaPrime,
You should set the following properties of the WebMonthView:
EnableAppStyling="True" StyleSetName="Appletini" StyleSetPath="ig_res"
Please let me know if this helps.
