310
Changing an <img> icon on mouse click
I have the following SqlDataSource and WebDataGrid.
<asp:SqlDataSource ID="SqlDataSource1" runat="server"
ConnectionString="<%$ ConnectionStrings:PetroLandConnectionString %>"
SelectCommand="SELECT * FROM [Counties] WHERE ([StateID] = @StateID)" >
  <SelectParameters>
    <asp:ControlParameter ControlID="DDLStates" DefaultValue="0" Name="StateID"
    PropertyName="SelectedValue" Type="Int32" />
  </SelectParameters>
</asp:SqlDataSource>
<ig:WebDataGrid ID="WebDataGrid1" runat="server" DataSourceID="SqlDataSource1" Height="750" Width="800" AutoGenerateColumns="False">
  <Columns>
    <ig:BoundDataField DataFieldName="ID" Key="ID" Hidden="true">
      <Header Text="ID"  />
    </ig:BoundDataField>
    <ig:TemplateDataField Key="Options" Width="60px">
      <Header Text="Options"  />
    <ItemTemplate>
      <asp:UpdatePanel ID="UpdatePanel1" runat="server">
        <ContentTemplate>
                     <%#EnableDisable(Eval("ID"), Eval("StateID"), DetermineActiveInactive(Eval("ID")))%>
          <asp:ImageButton ID="ImageButton1" runat="server" ImageUrl="./icons/pen_24.png" CommandName='edit'
          CommandArgument='<%# Eval("Id")%>' ToolTip="Edit" />
        </ContentTemplate>
      </asp:UpdatePanel>
    </ItemTemplate>
  </ig:TemplateDataField>
  <ig:BoundDataField DataFieldName="Name" Key="Name">
    <Header Text="Name" />
 </Columns>
 <Behaviors>
  <ig:EditingCore>
   <Behaviors>
    <ig:CellEditing>
    </ig:CellEditing>
   </Behaviors>
  </ig:EditingCore>
  <ig:RowSelectors>
  </ig:RowSelectors>
  <ig:VirtualScrolling>
  </ig:VirtualScrolling>
  <ig:Filtering>
  </ig:Filtering>
  <ig:Sorting>
  </ig:Sorting>
  <ig:ColumnResizing>
  </ig:ColumnResizing>
  <ig:ColumnMoving>
  </ig:ColumnMoving>
  <ig:Paging PageSize="10">
  </ig:Paging>
 </Behaviors>
</ig:WebDataGrid>
And here is the code for "EnableDisable()":
Function EnableDisable(ByVal eID As Integer, ByVal sID As Integer, ByVal EnabledDisabled As Boolean) As String
If EnabledDisabled = True Then
  Return "<a href='EProspects.aspx?t=" & STR.EncryptStringHex(tProjectID, 12) & "'><img src='/icons/ok_24.png'
          onclick='EnableDisableCounty()'></a>"
Else
  Return "<a href='EProspects.aspx?t=" & STR.EncryptStringHex(tProjectID, 12) & "'><img src='/icons/NOTok_24.png'
End If
End Function
When a user clicks on the <img> (which is either a check mark or an X depending on some condition) I want the check mark to change to an X or vice versa without performing a postback.  I need the user to stay on the page, but still be able to change the check mark to an X or vice versa.  What I have shown above was not designed with this functionality in mind, so I am trying to change it to achieve this functionality.  How can I do this in the WebDataGrid without doing a postback or leaving the page?
