I have a WebDataMenu1 with ItemClick event on MasterPage. I set a debug point in the ItemClick event and run at IE, it will perform to debug point. But in Google Chrome browser, it will not perform to debug point.
How can I fix it? thanks.
Hi Su,
Let me know if you still need assistance with the matter.
I'm still unable to reproduce the issue. Please provide me with a small isolated sample, in order to be able to investigate it further.
Hi Nikolay,
Sorry, here is my partial code:
default.aspx: MasterPageFile="~/MasterPage.master"
default2.aspx: MasterPageFile="~/MasterPage.master"
default2.aspx.cs:if (!IsPostBack){ Response.Write(Session["myID"].ToString());}
MasterPage.master.cs:protected void Page_Load(object sender, EventArgs e){if (!IsPostBack){WebDataMenu1.Items.Add("Root Item", "Root_0");WebDataMenu1.Items[0].Items.Add("Child Item", "Child_0_1");WebDataMenu1.Items[0].Items[0].NavigateUrl = "Default2.aspx";WebDataMenu1.Items[0].Items.Add("Child Item", "Child_0_2");WebDataMenu1.Items.Add("Root Item", "Root_1");WebDataMenu1.Items[1].Items.Add("Child Item", "Child_1_1");WebDataMenu1.Items[1].Items.Add("Child Item", "Child_1_2");WebDataMenu1.Items.Add("Root Item", "Root_2");WebDataMenu1.Items[2].Items.Add("Child Item", "Child_2_1");WebDataMenu1.Items[2].Items.Add("Child Item", "Child_2_2");}}
protected void WebDataMenu1_ItemClick(object sender, Infragistics.Web.UI.NavigationControls.DataMenuItemEventArgs e){ Session.Add("myID", e.Item.Key);}
The events after WebDataMenu1_ItemClick, be fired flow is: at IE: WebDataMenu1_ItemClick → defautl.Page_Load
at Chrome: only defautl.Page_Load be fired
Hi Su Min,
I have tested this scenario using v12.2.20122.1007 but I could not reproduce the issue. I am attaching a small sample replicating your setup.
