I have an Ultrawebgrid with a valuelist column (statically loaded with values at Page_Load). When the user selects a value (captured at AfterCellUpdated event), another ValueList is loaded (based on the first valuelist's selected value) and populated for the user to also select.
My problem is that when the grid is loaded, while the second column values are displayed, when clicking on the cells themselves, no valuelist dropdown is shown, because this is not created until the first column dropdownlist is updated.
What I would like to do is to have both value lists loaded and available at page_load, so as to enable editing of the second valuelist without having to change the first column's value first.
Any ideas on how this can be achieved? Which event should I hook this up to?
Hi Nikolay
I will close this question; thank you very much for your help.
Hi cloucas,
I'm following up to see if you have been able to resolve your issue.
I could not understand what is exactly the issue. Could you please clarify, and explain the steps to reproduce this behavior? Thank you.
Nikolay Hi
Thanks for your input. At this time I have no other questions on this matter; another issue I am facing is that I have a number of users complaining that whenever the grid is loaded with more and more rows, the time to refresh the totals while jumping from one cell to the other in entering data increases. They claim that after 30 or so rows, they notice a large delay (more than a few seconds). Do you know if there are any limitations?
Hello cloucas,
I'm just checking if you have any other questions.
