I am trying to migrate to 11.2 from 10.3, I can't seem to find the correct assembly reference for 11.2.
Many of the 10.3 classic controls were removed in 11.2, but the UltraWebChart isn't listed as one of them, there are also no references to it in the migration guide.
What is the name of the new assembly or the correct assembly tag for using UltraWebChart in 11.2?
Current tags are:
<%@ Register TagPrefix="igchart" Namespace="Infragistics.WebUI.UltraWebChart" Assembly="Infragistics4.WebUI.UltraWebChart.v10.3, Version=10.3.20103.2120, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
<%@ Register TagPrefix="igchartprop" Namespace="Infragistics.UltraChart.Resources.Appearance" Assembly="Infragistics4.WebUI.UltraWebChart.v10.3, Version=10.3.20103.2120, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
<%@ Register TagPrefix="igchartdata" Namespace="Infragistics.UltraChart.Data" Assembly="Infragistics4.WebUI.UltraWebChart.v10.3, Version=10.3.20103.2120, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
Hi elPato79,
The assembly names are the same, you only need to change the version numbers - for example:
<%@ Register TagPrefix="igchart" Namespace="Infragistics.WebUI.UltraWebChart" Assembly="Infragistics4.WebUI.UltraWebChart.v11.2, Version=11.2.20112.2178, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
Let me know if this helps.
Thanks for the prompt response Nikolay. Seems like the simplest answer many times is the right one :) The namespace for this chart control is different than the standard editor/grid controls, that is what was throwing me off, I was using the incorrect namespace.
I was also not expecting to see any further references to "Ultra" in the namespace. For all of the other controls that migrated to the new framework, it seems like they moved away from the use of Ultra, i.e. UltraWebGrid => WebGrid, etc.. Looks like there were a few legacy controls that were not part of the migration.
I'll mark this question as answered. Thanks for your help.
I'm glad you solved your issue.
If you have any other concerns, please feel free to contact me.
