I'm trying to add functionality to the webDataGrid so the user can copy multiple rows from Excel and then paste them in at the end of the existing grid. I've cannibalized the copy paste code from a different thread, and got that to work as far as pasting over existing data, but I can't get it to just paste in at the end of the grid.
Here's the template code:
<ig:WebDataGrid
ID="WebDataGrid1"
runat="server"
Height="350px"
Width="400px"
AutoGenerateColumns="False"
DataKeyFields="ID"
ClientIDMode="Static"
<ClientEvents KeyUp="keyUp" />
<Behaviors>
<ig:Selection CellClickAction="Cell" CellSelectType="Single">
</ig:Selection>
<ig:Activation>
</ig:Activation>
<ig:EditingCore>
<ig:CellEditing></ig:CellEditing>
</Behaviors>
</ig:EditingCore>
<Columns>
<ig:BoundDataField Key="ID" DataFieldName="ID" Hidden="true" />
<ig:BoundDataField Key="ReqID" DataFieldName="ReqID" Header-Text="ReqID" />
<ig:BoundDataField Key="Description" DataFieldName="Description" Header-Text="Description" />
</Columns>
</ig:WebDataGrid>
And here's the javascript I'm using for the paste operation:
function keyUp(grid, args)
var evt = args.get_browserEvent();
if (evt.ctrlKey && evt.keyCode == 86) // Ctrl-V
var activeCell = grid.get_behaviors().get_activation().get_activeCell();
var clipboardText = getClipboardData();
if (activeCell && clipboardText)
//initialize grid variable
var grid = $find("WebDataGrid1");
var rows = grid.get_rows();
// Excel stores its data in text clipboard separated
// by \n between rows and by \t between cells
var pasteData = clipboardText.split("\n");
// Last row may be a dummy row
if (pasteData[pasteData.length - 1].length == 1 && pasteData[pasteData.length - 1][0] == "")
delete pasteData[pasteData.length - 1];
var newID = grid.get_rows().get_length();
for (var i = 0; i < pasteData.length; i++) {
newID = newID + 1;
pasteData[i] = pasteData[i].split("\t");
var newRow = new Array(newID, "ReqID", "Description");
rows.add(newRow);
var rowDataIndex = 0;
var rowIndex = activeCell.get_row().get_index();
var rowIndex = grid.get_rows().get_length()
// Let's paste until the end of our clipboard data or until the end of the grid rows
while (rowDataIndex < pasteData.length && rowIndex < grid.get_rows().get_length())
// var row = grid.get_rows().get_row(rowIndex++);
var row = grid.get_rows().get_row(newID);
var cellDataIndex = 0;
// var cellData = pasteData[rowDataIndex++];
var cellData = pasteData[newID];
var cellIndex = activeCell.get_index();
//Let's paste until the end of the clipboard data or until the end of the cells
while (cellData && cellDataIndex < cellData.length && cellIndex < row.get_cellCount())
var text = cellData[cellDataIndex++];
if (text === null)
break;
var cell = row.get_cell(cellIndex++);
cell.set_value(text);
Right now all it does is paste the one row at the end. I feel like I'm close on this, just not that experienced with Infragistics and rusty on Javascript. Any suggestions would be appreciated.
I figured out a workaround. Seen a lot of people looking for this, hope it helps
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="copyPaste.aspx.cs" Inherits="copyPaste" %>
<%@ Register Assembly="Infragistics4.Web.v11.1, Version=11.1.20111.2225, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
<asp:PlaceHolder runat="server">
//initialize rows variable
//paste clipboard data into
var txtData = document.getElementById("<%= txtPasteData.ClientID %>")
txtData.value = pasteData;
var check = "<%= Button1.ClientID %>";
return __doPostBack("<%= Button1.ClientID %>", '');
return false;
var _browserPasteData = null;
function getClipboardData()
if (_browserPasteData) // Safari/Chrome logic
return _browserPasteData;
if (window.clipboardData) // IE logic
return window.clipboardData.getData("Text");
else if (typeof(netscape) != "undefined") // Firefox logic
netscape.security.PrivilegeManager.enablePrivilege('UniversalXPConnect');
var clip = Components.classes["@mozilla.org/widget/clipboard;1"].createInstance(Components.interfaces.nsIClipboard);
var trans = Components.classes["@mozilla.org/widget/transferable;1"].createInstance(Components.interfaces.nsITransferable);
trans.addDataFlavor("text/unicode");
clip.getData(trans, clip.kGlobalClipboard);
var str = new Object();
var len = new Object();
trans.getTransferData("text/unicode", str, len);
if (str)
return str.value.QueryInterface(Components.interfaces.nsISupportsString).toString();
return null;
// In Safari/Chrome the clipboard data can only be accessed
// from the onpaste event. In this sample the event is handled
// off the body element: <body onpaste="browserPaste(event)">
function browserPaste(e)
_browserPasteData = e.clipboardData && e.clipboardData.getData ?
e.clipboardData.getData('text/plain') : null;
</script>
</asp:PlaceHolder>
</head>
<form id="form1" runat="server">
<asp:ScriptManager ID="ScriptManager1" EnablePageMethods="true" runat="server"></asp:ScriptManager>
<div>
ID="WebDataGrid1" EnableAjax="true"
Height="700px"
Width="600px"
ClientIDMode="Static">
<ig:CellEditing>
</ig:CellEditing>
<asp:TextBox ID="txtPasteData" onblur="__doPostBack('Button1','')" AutoPostBack="true" Height="0" Width="0" runat="server" />
<input id="Button1" type="button" value="button" style="display:none" runat="server" />
<input type="hidden" name ="__EVENTTARGET" value ="">
<input type="hidden" name ="__EVENTARGUMENT" value ="">
</div>
</form>
</body>
</html>
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Data;
public partial class copyPaste : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
if (!Page.IsPostBack)
this.WebDataGrid1.DataSource = this.GetDataSource();
this.WebDataGrid1.DataBind();
else if(this.txtPasteData.Text.Length > 0)
string pasteData = txtPasteData.Text;
splitData(pasteData);
txtPasteData.Text ="";
protected void splitData(string pastedData)
//var pasteData = clipboardText.split("\n");
string[] separator = new string[] { "," };
string[] strSplitArr = pastedData.Split( separator, StringSplitOptions.RemoveEmptyEntries);
AddToDataSource(strSplitArr);
DataTable GetDataSource()
if (this.Session["DataSource"] != null)
return this.Session["DataSource"] as DataTable;
DataTable table = new DataTable();
table.Columns.Add("ID", typeof(int));
table.Columns.Add("ReqID", typeof(string));
table.Columns.Add("Description", typeof(string));
//table.PrimaryKey = new DataColumn[] { table.Columns[0] };
table.Rows.Add(new object[] { 0, "1.1.1", "Site must follow BOA CSS standards" });
table.Rows.Add(new object[] { 1, "1.1.2", "Need admin tables to change drop down values" });
table.Rows.Add(new object[] { 2, "1.1.3", "Must have error handling" });
table.Rows.Add(new object[] { 3, "1.1.4", "Log files need to be accessible" });
this.Session["DataSource"] = table;
return table;
protected void AddToDataSource(string[] newValues)
DataTable dt;
//pull datatable out of session variable if it exists
dt = (DataTable)Session["DataSource"];
else
dt=new DataTable();
//This is the select query for Max
string selectCommand = "Max(ID)";
//returns the Max EmploeeID
int MaxID = Convert.ToInt32((object)dt.Compute(selectCommand, string.Empty));
int ID = MaxID + 1;
//split ReqID and description, add ID field for Infragistics
foreach (string arrStr in newValues)
string[] split = arrStr.Split(new Char[] { '\t' });
if (split.Length > 0)
string ReqID = split[0];
string Description = split[1];
dt.Rows.Add(
new object[] {ID, ReqID, Description });
ID = ID + 1;
this.WebDataGrid1.DataSource = dt;
