I am using an ultrawebgrid in which I have two ultragridbands defined. I want to change a value in the child band however, when I use updateRowBatch, it does not realize a change has been made to the child band. It only tries to look for changes in the parent band. If I test the value of e.Row.Band.Key it is always the key of the parent band, but it never tests for the key of the child band. I don't have this issue with InitializeRow. That is able to initialize all rows in the grid whether they are part of the parent band or child band. This is what I am using:
Protected Sub ReceiptGrid_UpdateRowBatch(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.RowEventArgs) Handles ReceiptGrid.UpdateRowBatch
Is it possible to update cells in a child band via updateRowBatch?
Are you able to resolve this issue. I am facing the same issue.After Upgrade to Version=11.1.20111.2064. UltraWebGrid_UpdateRowBatch is not firing. Any resolution.Thanks
Hello tennisne1,
If you need any further assistance with the matter, please let me know.
Hi tennisne1,
I tested the UltraWebGrid with two bands and the UpdateRowBatch event was correctly firing for updates in the child band, too. I used v11.1.20111.2178. What version of Infragistics controls are you using? Is it possible for you to attach a small sample, reproducing the issue?
Thank you.
