I'm using webdatatree for navigation between frames. On click on the server side I form the navigate URL. Then in AJAXResponse handler I want to navigate to that URL using frames location. Where would you recommend to store the path, so that I can obtain it already in AJAXResponse handler? Perhaps some extra ajax control? I tried storing it in one of WebDataTree nodes, in its Target property just to be logical. But when I obtain it on the client side, it holds the old value.
I tried this.WebDataTree1.CustomAJAXResponse.Tag = "myURL";
and then var path = e.get_customResponseObject().Tag; in WebDataTree1_AJAXResponse.
It susccessfully retrieves the pathstring, but then throws the following JS error:
Microsoft JScript runtime error: Unable to get value of the property 'setAttribute': object is null or undefined
in the second line of
buildNodeLiId: function(nodeElem, adr) { var id = "x:1.1:adr:" + adr; nodeElem.setAttribute("id", id); nodeElem.setAttribute("adr", adr); }.
If in server side i comment this.WebDataTree1.CustomAJAXResponse.Tag = "myURL"; and use fixed URL, it works ok.
The same is if I use not Tag, but Message
Any help?
Thanks for support, I hope there is a resolution.
I have another issue... http://es.infragistics.com/community/forums/p/75061/379298.aspx#379298 And Thanks.
Hello Andrey,
I have investigated the issue and I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 125951. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I will leave this case open and update you with any new information after the review. You can also continue to send updates to this case at any time. You can view the status of this development issue by going to “Account > Support Activity” on our website, selecting case with number CAS-103357-K6D8D7 and clicking the "Development Issues" tab.
If you need more information, please feel free to contact us.
I also tried it in recently acquired 12.2.20122.1007. It gives the same error.
Hello, Nikolay
Unfortunately, it gives the same error as described earlier - it's reproducable in that sample solution I attached earlier. I'm right now on 11.1.20111.2238.
I would suggest you to use the AdditionalProperties property of the CustomAJAXResponse. You can add a object in code-behind and get its value in AJAXResponse client-side event like this:
this.WebDataTree1.CustomAJAXResponse.AdditionalProperties.Add("key1", "SomeURL");
function WebDataTree1_AJAXResponse(sender, e){ var url1 = e.get_customResponseObject().AdditionalProperties.key1;}
Let me know if this helps.
