Hahaha, well Viktor, that was funny.
I cannot force the end-user to FIRST RENAME THE IMAGE BEFORE UPLOADING, that is not the right way.
I want to do that programmatically, not manually.
thanks anyway.
Hi pallavipatni,
The "Modify image ---" dialog has the "Browse..." button. When it is clicked, then windows dialog "Choose File to Upload" should appear. You may search for any image file which is supported (defined by extensions) by WebHtmlEditor and right-mouse click in it. The windows should show you pop-up menu with various options. One of them should be "Rename". Click on that option and file name should go into edit mode. You may rename that file. If you after that will click button Open, then that renamed file will be available for upload. When you after that click "Upload File" button in "Modify image" dialog, then confirmation message should pop-up and that file should appear in the "Files" list.
Thanks for the response.Yes i know the 'Files' displays images from the server only. And you got it right i was asking about the upload image only. Now can you please tell me how to do that? because im not able to find that particular process where that browse button's execution taking place, so that i can change edit that name of the file aftr browsing it.
thanks
If you ask about change names of files displayed within "Files" of the "Modify image" dialog, then that is not possible. Those files are located on server and end user only may request to show them in editor.
If you ask about the "Upload File" button, which targets the INPUT filled by action of "Browser..." button, then, I guess, changing file name should be possible. The "Browse..." button opens standard windows "upload file" dialog. While browsing through available local files (if it is supported by end user machine), the end user may find a particular file, change its name and "Open" (request to upload) that renamed file.
