HI,
I try to display a string "11111" as five different images in wdg by using the row_initialized Event. That is OK. Now i want to edit this string to e.g. "01011". Thinking of a webDropDown with five entries (checkbox) i would to construct this string, but i don't know how to create different Templates for showing and editing in a template-field.
Can someone give me a little advice?
Hello Schnapper,
Thank you for your reply. Glad that you were able to implement your requirement using the RET (I did not realize the row editing template was an option in this case).
Please do not hesitate to contact me if you have any further questions regarding this scenario.
I did it with the rowEditingTemplate. Cause of some malfunction of my workstation first it didn't worked so i ask this question. Now I display the data in template-field of column and implement a dropDown with checkBoxes for all Positions of the string. Thanks for your sasmple, i can use it for an other part of my solution.
While only one template may be used per column in WebDataGrid, your requirement may be achievable by hiding the WebDropDown control in the template and making it visible upon a click on the templated cell. I am attaching a small sample illustrating a possible approach to tackle this scenario. Please note however that this is a custom implementation and is not related with the grid's EditingCore behaviors.
Please let me know if this helps.
