Hallo,
i use the simpliest WHDG example from Getting Started with WebHierarchicalDataGrid and add only one selection behavior like this.
<Behaviors> <ig:Selection CellClickAction="Row" RowSelectType="Single" CellSelectType="None" > </ig:Selection></Behaviors>
There is different selection behavior in FF and IE.
After selecting any row from ChildDataSource WHDG scroll up in IE to the selected row in ParentDataSource. So, if your ChildDataSource has more rows than height of WHDG, then you can't see anymore the selected row.
Hi pobo001,
Thank you for sharing your solution with the community.
Please let me know if you have any other questions.
Solved.
Add <ig:Activation Enabled="true" /> to behavior to solve the problem.
