1840
Complex structure in a tree node
i use VS 2010, .Net 4.0 and NetAdvantage 10.2 with a WebDataTree. I want to add a jquery mobile slider to some 'checkbox' tree node (it is a map-application where the user can select some tile layer by check the node, the slider is for the transparency of each layer).
I try to use templates, but get some error from the microsoft ajax js framework (strange). Is it possible to add such element to some tree nodes? What is the best way to do this?
Btw, the tree is static; i set the structure and all behavior in the aspx code.
Thanks for help
Patric
