Is there a way to display the NullText of a WebTextEditor when the TextMode="Password", but keep the characters a user is typing masked?
I have the editor defined as such: <ig:WebTextEditor ID="PasswordWebTextEditor" runat="server" TextMode="Password" NullText="Enter Password">
I want the user to see the NullText value when the focus is not on the control. Currently the control displays "************" for the NullText.
I tried changing the "type" of the editor through client focus event in a javascript function, but that did not work.
function PasswordWebTextEditor_Focus(sender, eventArgs) { sender.type = "password"; }
function PasswordWebTextEditor_Blur(sender, eventArgs) { sender.type = "text"; }
-sandor
Hello,Please let me know if you have any further questions regarding this issue.
Hello Sandor,I tested the sample with just changing the used assembly to be 11.1.20111.2238 which is the latest service release for 11.1. I tested with IE 9, Chrome, FF 14, Opera 12 and none of the browsers provided the same issue as the one you are facing. Please let me know if you are using modified version of the sample or different browser / browser version.
Nikifor,
Thank you for the sample code. Unfortunately, it still does not work for me. After implementing it, I get the following JScript error within the Initialize event:
"Microsoft JScript runtime error: Could not get the type property. This command is not supported."
function PasswordWebTextEditor_Initialize(sender, eventArgs) {
if (ig_controls.PasswordWebTextEditor.get_value() == "") {
ig_controls.PasswordWebTextEditor.get_element().type = "text"; //<-- error="" here="" span="">
*** I am using Infragistics ASP.NET 11.1 controls. ***
It looks like the "type" attribute is not allowed to be modified.
When I attempt to change the object's "type" value within the Watch window of Visual Studio 2010, I get "The value could not be set. Please check your entry." message.
Also, I had to set the ClientIDMode of the password editor to "Static" for the "ig_controls.PasswordWebTextEditor" statement to work.
Trying to change the "type" value in the "Immediate" Window after breaking in the code, I get this:
?ig_controls.PasswordWebTextEditor.get_element().type = "text"
When I try
?sender.type = "text"
That works, but when I look at the value of
it still shows "password".
Is it possible my Infragistics environment is not configured correctly??
HiI am attaching sample which implements what you are trying to achieve. Sample is tested with IE 9 and Chrome. Please let me know if you have any other questions.
