I am using a Calculated field in an UltraWebGrid and know how to set it up to create a the Grid Totals.
One of my columns is a percentage column and the correct footer value is not the sum of the percentage values, rather it is (sum(col3) / sum(col1)). Is there a document for building the UltraCalc fomula for use in this footer field?
Hello raj_sainThank you for your feedback. It seems the Microsoft have removed this page. When you came back to this issue and if you need to see the sample running i will create a support ticket and send the whole sample to you through this support ticket.
I cannot access the database file that you have linked to. The Microsoft site shows an error when clicking the link.
I looked at the code in the .cs file and it shows how to do a count and sum.
I have moved on from this as other higher priority projects are taking precedence. I'll get back if and when I need to use UltraCalc again.
Hello Raj,Please let me know if you have any further questions regarding this issue.
Hello Raj,Please take a look at the attached sample. You will have to download Nwind.mdb from the following link - http://www.microsoft.com/en-us/download/details.aspx?id=19704 and place it in App_Data folder in order to run the sample.
The link shows an example of the sum() formula. I need a link to a more comprehensive list of formulae. Specifically I need to be able to enter the equivalent of (sum(col3) / sum(col1)). Entering this does not seem to have any effect therefore I am looking for the correct syntax.
