1810
WebDataTree and Drag&Drop in Firefox
We want to drag a WebDataTree's Node to a target that is not a WebDataTree, so we disabled the DragDrop settings in the tree and we are using the Drag&Drop Framework.
The problem is that in Firefox (13.0.1) por some reason the drag is "canceled", any help?
Something else : sometimes, in IE8, I have a similar behaviour that I am not able to reproduce yet
This is the code:
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="DnDigWDT.aspx.cs" Inherits="DnDigWDT" %>
<%@ Register Assembly="Infragistics4.Web.v12.1, Version=12.1.20121.2020, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.Web.UI.NavigationControls" TagPrefix="ig" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
</head>
<body>
<form id="form1" runat="server">
<asp:ScriptManager ID="ScriptManager1" runat="server">
<Scripts>
<asp:ScriptReference Assembly="Infragistics4.Web.v12.1, Version=12.1.20121.2020, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"
Name="Infragistics.Web.UI.SharedScripts.igDragDrop.js" />
Name="Infragistics.Web.UI.Scripts.5_igObjects.js" />
Name="Infragistics.Web.UI.SharedScripts.igAnimation.js" />
</Scripts>
</asp:ScriptManager>
<div>
<ig:WebDataTree ID="WebDataTree1" runat="server" Height="300px" Width="200px" AutoPostBackFlags-NodeClick="Off" DragDropSettings-AllowDrop="false" DragDropSettings-EnableDragDrop="false">
<Nodes>
<ig:DataTreeNode Text="Node1"><Nodes><ig:DataTreeNode Text="Node1.1" Draggable="false"></ig:DataTreeNode></Nodes></ig:DataTreeNode>
</Nodes>
</ig:WebDataTree>
<div id="targetDiv" style="background-color:Yellow;width:200px;height:200px">Target</div>
</div>
<script language="javascript" type="text/javascript">
Sys.Application.add_load(inicializarDragDrop);
function inicializarDragDrop() {
var ddb = new $IG.DragDropBehavior();
ddb.addSourceElement($find("WebDataTree1").getNode(0).get_childNode(0).get_element());
ddb.addTargetElement(document.getElementById("targetDiv"));
</script>
</form>
</body>
</html>
Parents
  • 49378
    Verified Answer
    Hello rickycl,
    I have researched the matter and there is a known issue with the latest version of Firefox and the DragAndDrop Framework. I have created a support ticket for you regarding this matter - CAS-96119-YBC0DC and associated it with the existing work item (112508) so that you will be automatically notified when a resolution is available.
    Please do not hesitate to contact me if you need more information.
Reply Children
No Data
