475
Adding Parent row on button Click Event
Am working with WHDG for the past 1 week and now i can able to set the values for the WHDG from dataset.I have a button outside of the grid on the button clicking event i want to add the new row to the grid.When i tried this what happening is during postback the exixting rows has been replaced with the newly added rows.
How can i add the new empty row(Parent Band) to the previously existing row.?
Hsakarp.
  • 15979
    Verified Answer
    Hello Hsakarp,
    You can use the following example function to add rows to the parent band:
    function AddRowToGrid() {
    var grid = $find("WebHierarchicalDataGrid1");
    var row = new Array(10000, 445, 0, 321);
    grid.get_gridView().get_rows().add(row);
    This function should be executed on Client-Side.
    If you want to add records from Server-Side you will have to modify your Data Source by adding the record in it and then rebind the grid.
    I hope that this information will be useful.
