I'm using a webchart with a customizable rendering scenario, user can switch between Flash and Image.
I can't reproduce the same tooltips used in Image scenario using Flash and HotTracking properties, It doesn't seem work or nothing appear when I move the pointer over the Flash chart.
Probably I did an error, anybody can tell me the how set correctly the hottracking properties for Flash scenario?
Erik
Tooltips are not available in Flash rendering, as HotTracking is not available in Image rendering. Check the properties under "Tooltips" to configure appearance settings for HotTracking and Tooltips.
