80
WebDataMenu javascript error in IE8
I have a WebDataMenu inside of a tab of an AjaxControlToolkit TabContainer, with a few WebImageButtons arranged horizontally. The page renders correctly in IE9, Chrome, etc, but when I switch my IE to IE8 mode and IE8 standards, I see a javascript error in some of the javascript code, in a function named __resizeListItems (line 468 is bolded and underlined):
Line: 468
Error: Invalid argument.
__resizeListItems:function(item)
   /* 2010-02-18 Bug#16534 - get the group height and go resize inner LI's
    * do not set line-height accordingly, eventhough it is the only way
    * to make texts appear aligned vertically.
    * setting line-height will propaged throughout the children which is not desired!
   var group = this.get_element().getElementsByTagName("UL")[0];
   if(!$util.isNullOrUndefined(item))
       group = item._get_subgroup();
   var childItem = this.getItems().getItem(0);
   var grpSettings = this._menuGroupSettings;
       childItem = item.get_childItem(0);
       grpSettings = item.get_itemsGroupSettings();
   if($util.isNullOrUndefined(childItem) || $util.isNullOrUndefined(grpSettings))
       return;
   if(grpSettings.get_orientation() == $IG.Orientation.Vertical)
       return;
   if(childItem._element.style.height != "" || childItem._element.style.height.length > 2) return;
   var MaxHeight = 0;
   var nChildItem = childItem;
   while(nChildItem != null)
            if(!nChildItem.get_isSeparator())
                (nChildItem._element.offsetHeight > MaxHeight) ? MaxHeight = nChildItem._element.offsetHeight: null;
            nChildItem = nChildItem.get_nextItem();
   if(childItem != null)
     MaxHeight -= $util.toIntPX(null, 'paddingBottom', 0, childItem._element);
       MaxHeight -= $util.toIntPX(null, 'paddingTop', 0, childItem._element);
       MaxHeight -= $util.toIntPX(null, 'borderTopWidth', 0, childItem._element);
       MaxHeight -= $util.toIntPX(null, 'borderBottomWidth', 0, childItem._element);
       MaxHeight -= $util.toIntPX(null, 'marginBottom', 0, childItem._element);
       MaxHeight -= $util.toIntPX(null, 'marginTop', 0, childItem._element);
       MaxHeight -= $util.toIntPX(null, 'paddingBottom', 0, group);
       MaxHeight -= $util.toIntPX(null, 'paddingTop', 0, group);
       MaxHeight -= $util.toIntPX(null, 'borderTopWidth', 0, group);
       MaxHeight -= $util.toIntPX(null, 'borderBottomWidth', 0, group);
       MaxHeight -= $util.toIntPX(null, 'marginBottom', 0, group);
       MaxHeight -= $util.toIntPX(null, 'marginTop', 0, group);
        while(childItem != null)
            if(!childItem.get_isSeparator())
                childItem._element.style.height = MaxHeight + 'px';
                //childItem._element.style.lineHeight = groupHeight + 'px';
            childItem = childItem.get_nextItem();
When I step through this with a debugger, i see that MaxHeight gets set to '-2' from the code above, and then IE does not show the entire TabContainer when this error occurs.
I've tried setting and removing Height values on the WebImageButtons with no luck. I also verified there are no CSS attributes being applied to the WebDataMenu or WebImageButtons.
