I have a WebDataGrid that has a template field in it that is set so when the user clicks on the hyperlink, a new window opens and displays the info I want displayed. This is how it looks so far:<ig:TemplateDataField Key="Row_ID_Hyperlink" Width="5%"> <ItemTemplate> <asp:HyperLink ID="HyperLink1" runat="server" NavigateUrl='<%# Eval("URL") %>' Text='<%# Eval("Row_ID_Hyperlink") %>' Target="_blank"> </asp:HyperLink> </ItemTemplate> <Header Text="Row ID" /></ig:TemplateDataField>When the window opens, it opens with the back button, toolbars and everything else at the top. I really just want it to be more like a popup window.Any suggestions on how I can get this to work?
I figured it out:<ig:TemplateDataField Key="Row_ID_Hyperlink" Width="5%"> <ItemTemplate> <asp:HyperLink ID="HyperLink1" runat="server" Font-Underline="True" ForeColor="Blue" NavigateUrl=<%# String.Format("BLOCKED SCRIPTvoid(window.open('Change_History.aspx?Table_Name=tblAIM_Settings&Key_Value=" & Eval("Row_ID") & "','_blank','width=800,height=600,toolbar=no,status=yes,scrollbars=yes,resizable=no'))", Eval("Row_ID")) %> Text='<%# Bind("Row_ID") %>'></asp:HyperLink> </ItemTemplate> <Header Text="Row ID" /></ig:TemplateDataField>
