Infragistics.WebUI.UltraWebChart.UltraChart
DeploymentScenario.FilePath property requires a path to a folder where Ultrachart creates a image file. Is there any interface that can be implemented to override this feature?
How do I make this with Windows Azure Blob Storage?
what NetAdvantage version have enabled this support?
Thanks.
Hi Jhon,
I've just made a sample that woks on Azure platform. The chart is setup to work with Session Deployment scenario. Also,I tested with FileSystem deployment scenario but I'm getting an error, I suppose a little more research is required for that. I hope this will help you:
http://forums.infragistics.com/forums/t/70459.aspx
Rado
