hi.!
When i deploy the asp.net app in production server it's given an error.
as follows
Server Error in '/iletest' Application.Configuration ErrorDescription: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.Parser Error Message: Could not load file or assembly 'Infragistics4.WebUI.Documents.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.Source Error:Line 14: <add assembly="Infragistics4.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB" />Line 15: <add assembly="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089" />Line 16: <add assembly="Infragistics4.WebUI.Documents.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB" />Line 17: <add assembly="System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A" />Line 18: <add assembly="Infragistics4.WebUI.Excel.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB" />Source File: C:\inetpub\wwwroot\iletest\web.config Line: 16Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.1
Hello, I got the version 13.1 and installed. I am getting the follwoing error in my local when I try to run the application. Any help would be appreciated.
Description: An error occurred during the parsing of a resource required to service this request. Please review the following specific parse error details and modify your source file appropriately. Parser Error Message: Could not load file or assembly 'Infragistics4.Web.v13.1, Version=13.1.20131.2188, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.Source Error:
[No relevant source lines]
Source File: none Line: 0 Assembly Load Trace: The following information can be helpful to determine why the assembly 'Infragistics4.Web.v13.1, Version=13.1.20131.2188, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' could not be loaded.
=== Pre-bind state information === LOG: User = MININT-3B0KO0E\Manager LOG: DisplayName = Infragistics4.Web.v13.1, Version=13.1.20131.2188, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb (Fully-specified) LOG: Using host configuration file: LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config.LOG: Post-policy reference: Infragistics4.Web.v13.1, Version=13.1.20131.2188, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cbLOG: The same bind was seen before, and was failed with hr = 0x80070002.
Hello John,
It seems to me that there are still some references to dlls from your previous version (6.2) that are causing this exception. I would suggest you to search your whole project and replace all references to the old assemblies.
Hope this helps.
I have upgraded from Infragistics.WebUI.UltraWebGrid.v6.2 to Infragistics2.WebUI.UltraWebGrid.v11.1 and I receive the following error message:
Error 2 C:\inetpub\wwwroot\MediCOE\Content\controls\OrderBuilder.ascx: ASP.NET runtime error: Could not load file or assembly 'Infragistics.WebUI.UltraWebGrid.v6.2, Version=6.2.20062.1060, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified. C:\inetpub\wwwroot\MediCOE\Content\controls\OrderBuilder.ascx 1 1 MediCOE
I am unsure how to resolve this issue as it is not a problem amongst the 80 or so other pages. If there is some place to clear a cache or temporary files I would most certainly like to know the locations. This is an urgent matter as I need to perform a build for SQA today. Please provide me with assistance as soon as you can.
P.S. - I have uninstalled all prior versions of the Infragistics controls.
-Thanks,
John W
Hi Suhaib,
I'm glad to hear that.
Do not hesitate to ask if you have any other questions.
Thanks a lot , It's Work, Done.
Suhaib
