Hi i got this problem when my page load to my default.aspx
Object reference not set to an instance of an object. Description: An unhandled exception occurredduring the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [NullReferenceException: Object reference not set to an instance of an object.] Infragistics.Web.UI.GridControls.WebHierarchicalDataGrid.DataBind() +1080 System.Web.UI.WebControls.BaseDataBoundControl.EnsureDataBound() +82 Infragistics.Web.UI.GridControls.WebHierarchicalDataGrid.EnsureDataBound() +81 System.Web.UI.WebControls.BaseDataBoundControl.OnPreRender(EventArgs e) +22 Infragistics.Web.UI.Framework.Data.HierarchicalDataBoundControlMain.OnPreRender(EventArgs e) +196 Infragistics.Web.UI.GridControls.WebHierarchicalDataGrid.OnPreRender(EventArgs e) +36 System.Web.UI.Control.PreRenderRecursiveInternal() +80 System.Web.UI.Control.PreRenderRecursiveInternal() +171 System.Web.UI.Control.PreRenderRecursiveInternal() +171 System.Web.UI.Control.PreRenderRecursiveInternal() +171 System.Web.UI.Control.PreRenderRecursiveInternal() +171 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +842 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:2.0.50727.4927; ASP.NET Version:2.0.50727.4927
I already solve my problem. I just re create my webheirachical datagrid and and it works like a charm.
Thanks David
Thanks David,
Hi NewbApps,
This very well could be a bug on our side or from your sample. Without a sample to debug, it's hard to guess. Could you attach a small one here? The only other thing I could suggest at this point is to upgrade to the latest Service Release for your volume.
regards,
David Young
